🎉Community Raffle - Win $25
Join and Win
install Monarch 10.5 Pro network error
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
We are having problems installing a network version of Monarch 10.5 Pro on a Windows 10 laptop.
We are successful but when he tries to run Monarch he gets an error message the license is in use.
I have verified that no one else is using his ID and his User ID is unique. We have successfully installed Monarch 10.5 pro on 5 other Windows 10 machines.  So why is he having problems?
Corp will not allow us to upgrade to newer Versions.
Any ideas?
Ralph
1 - 2 of 21
    Altair Employee
    OP
    Hi Ralph,
    I hope you are well. It's been a while since I installed Version 10.5, but if my memory serves me correctly, we were still using the Network Started Packs with (typically) 4 user and 8 user add on packs.  Is that correct?
    It is really designed for use where the workstation is connected back to a central server.  If you install it on a laptop, you will be wasting the other users unless you open up a file share on that laptop for the other users to connect back to.  The license does not permit you to install the network component on more than one "server/workstation".
    However, if this is a limited deployment and you only need one user and you just happen to have a network version, you can proceed as follows:
    Step 1:       Run setup from the installation media and install the application to the "administration" location.  For this scenario, something like C:\MonarchNetwork would be appropriate.  In a normal network installation, it would be a location that all users could see.  For example, \\MyCentralServer\MonarchNetwork.
    After Step 1 is complete, you should have:
         A setup folder located in ……..\MonarchNetwork\Setup
         Links for License administration software, but no Monarch Software.
    Step 2:     Run setup *from the shared network location* ……..\MonarchNetwork\Setup
    You should now be able to administer users and run Monarch.
    I hope that resolves it and I haven't missed any steps. It's been a while!
    Of course, I'd heartily recommend Version 15 with License Server for a whole load of reasons!
    Regards,
    Steve.
    Altair Employee
    OP
    Hi Ralph,
    Regards,
    Steve.
    Steve,
    We  have Monarch correctly installed on the server and installed on 7 workstations which run without problems. We are running Windows 10 on all laptops.
    We are unable to install it on one laptop as described below.  We have uninstalled  and re-installed it multiple times using Windows without success.
    Could that laptop have a setting that is preventing this installation?
    Ralph
