"Neural Net ..... getting a positive Outcome"
Hi Everybody,
I'm running a simple X validation with a neural net trainer, and apply model and performance testing.
It's reading 5 columns of data and I'm comparing it against a simple 1,0 label.
I want the neural net to predict the outcome of 1 but it returns the 0 with no predictions of 1.
I have used another neural net program and it was the same until I added in a non-linear neuron ?
Is this possible to do in rapid miner.
Thanks in advance.
Thanks in advance.
1 - 7 of
71
Hi Sebastian,
Thanks very much, Do I need to insert a hidden layer for both outcomes 1, 0 ?
Also on a side issue how can i output a performance table to Excel.
I've tried write excel but i cant find how to assign the performance table result.
I've tried write performance but that doesn't output to excel format.
Regards Correlation
Regards Correlation
Hi, I'm still having problems with the 0/1 label in non linear classification mode.
I've tried adding a hidden label ( not sure if I've done this right )
Thanks for any help.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>I'm looking for a result like I can get using Bayes with the performance of 1 and 0
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process">
<process expanded="true" height="-20" width="-50">
<operator activated="true" class="retrieve" compatibility="5.0.10" expanded="true" height="60" name="Retrieve" width="90" x="42" y="59">
<parameter key="repository_entry" value="//MyRepository/Learning Data/Marketing Sales"/>
</operator>
<operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation" width="90" x="242" y="63">
<process expanded="true" height="435" width="325">
<operator activated="true" class="neural_net" compatibility="5.0.10" expanded="true" height="76" name="Neural Net" width="90" x="75" y="40">
<list key="hidden_layers">
<parameter key="null" value="-1"/>
</list>
</operator>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="24" y="34">
</operator>
<operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance" width="90" x="154" y="46"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
</operator>
<connect from_op="Retrieve" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="training" to_port="result 2"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
Hi Sebastian,
I have a database of 5 columns and a label column.
The 5 columns contain various marketing data and the label column is filled with only 1 and 0 indicating a sale or not.
When I run a bayes model and look at the results from the performance table, I get some results labelled as 0 and some results labelled as 1
This is exactly what i'm after.
But if I change the learning engines to say neural net ..... most of the time I only get a result against the 0 data.
You hinted earlier that the 1 and 0 information could be being misread and being labelled as regression rather than classification.
Is there anyway I can avoid this.
of course, just insert a hidden layer, it will be non linear. The type of the outcome neuron will be determined by the type of task: Linear for regression tasks, non-linear for classification. So I would check, if you 0/1 labeling is misinterpreted as numerical attribute resulting in a regression task.
Greetings,
Sebastian
