Memory problems
Hello,
I'm using version 4.6 of rapidminer and I'm using the example source operator to load in 1.2 Million datarows with 65 attributes. I've got 4 gb ram on my mac... is there any way to read in these amount of data, because i'm always getting a running out of memory problem and till then in takes 12 or more to read the data... is there a way and maybe a bit faster way in doing that `?
Greets Viktor
Greets Viktor
1 - 4 of
41
Hi Viktor,
if you have exported it as an .aml file, you probably have generated it with RapidMiner? You then could export it in chunks and reload it using a loop files operator in chunks and append it to the table. Since it's a more complex process, I save the design until you confirm that it is actually possible
Greetings,
Sebastian
Greetings,
Sebastian
-Gagi
