🎉Community Raffle - Win $25
Join and Win
Nominal to numerical wrong convertation
User: "SunnyLotusFlowe"
New Altair Community Member
Updated by Jocelyn
Hello all,
i have some problems with the Nominal to Numerical Operator:
i use the follow data set:
0 1 2 3 4 5 6 7 8 9 10
30 31 32
33 34 35
36 37 38 39 40 41 42 43 44 45 46
as Dat-Data  ( retail.dat)
My Workflow is:
Read Csv -> Split -> Replace Missing -> Nominal to Numerical
I have set the separation-char to  , (comma) to try the separation with the split-operator. the split operator does his job
and return alle attributes as nominal. now i wanted to convert nominal to numerical and instead of numbers like 30 32 ...
i get the numbers 0 , 1 , 2 ....
Is this a bug or did i something wrong . ???
greetings
Lotus
1 - 2 of 21
    User: "haddock"
    Synopsis
    Maps all values to real values (usually simply using the internal indices).
    User: "land"
    Hi,
    as haddock indicates: The operator documentation tells everything. Try to read the documentation of the "parse numbers" operator and you will be enlightened.
    Greetings,
      Sebastian
