🎉Community Raffle - Win $25
Join and Win
Memory looks low!
User: "johnhome"
New Altair Community Member
Updated by Jocelyn
Hello
My system monitor in RM5 is showing a Max memory of 61MB!
At the moment i cant even generate a test file with over 50000 records...  is there a setting i need to change?
I am running a 6 core 64bit widows 7 machine with 4gig of memory..
thanks
John
1 - 2 of 21
    User: "IngoRM"
    Hi,
    the reason is quite simple (at least I assume this): You have a 64-Bit Windows system but you downloaded the 32-Bit version of RapidMiner. In that case, only about 64 Mb of memory are used by RapidMiner. Just download and install the correct version and you will be fine.
    Cheers,
    Ingo
    User: "johnhome"
    OP
    Hi there thanks for the reply
    I was going to do that but i wanted the ingres bundle, which is only 32bit for download...  is there a way around this?
    Thanks
    John
