Altair RISE
Nominate Yourself Now!
b
User: "tehran"
Altair Community Member
Updated by tehran
b
1 - 19 of 191
    User: "plombard"
    Altair Employee
    Updated by plombard
    Another way of improvement is also to reduce the time step.
    User: "tehran"
    OP
    Updated by tehran
    I tested that but problem still remain
    User: "tehran"
    OP
    Updated by tehran
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    did you try to change the type of solver?
    To do it:  Solving >>  solving process options : edit >> linear system solver, change the type of solver (for example put MUMPS instead of ICCG)
    Can you send us your Flux project.
    Best regards.
    User: "tehran"
    OP
    Updated by tehran
    I have done these things perfectly, but after a few periods, the issue becomes divergent.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Thanks for the file. I will keep you informed.
    Best regards.
    User: "tehran"
    OP
    Updated by tehran
    Best regards.
    thank you
    User: "tehran"
    OP
    Updated by tehran
    Best regards.
    how can I get' jiles -atherton coef app.exe'?i have student version and i dont have any access to customer ftp to get that.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    The project that you send me is Flux 3D. but when I check it I found any volumes?
    I think you need to make an extrusion along Z axis to get the 3D geometry.
    can you confirme me?
    Thanks
    User: "tehran"
    OP
    Updated by tehran
    c
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    find attached the Jiles-Atherton model.
    User: "tehran"
    OP
    Updated by tehran
    thank you
    User: "tehran"
    OP
    Updated by tehran
    in hysteresis loop model in flux, with only 5 parameters we have all loop(in any BH curve) or we have only on loop?
    User: "tehran"
    OP
    Updated by tehran
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    About the number of loop, inside the model you have all loop.
    In your case, I strongly recommend you to use the model with Flux 2D.
    Best regards.
    User: "tehran"
    OP
    Updated by tehran
    Hi,
    Best regards.
    thanks for your response
    I use 2D but there is still  problem
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    HI,
    it is the same probleme as before?
    Send me your 2D project.
    User: "tehran"
    OP
    Updated by tehran
    HI,
    yes, i had.
    i deleted it after i recognize that it is not convergence.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Try to refine the mesh and decrease the step time.
    I need your Flux project to see why he does not converge.
    Best regards.
