🎉Community Raffle - Win $25
Join and Win
"handling ordinal data and attribute weighting"
User: "yogafire"
New Altair Community Member
Updated by Jocelyn
hello,
my first question is about handling ordinal data.
I have a dataset, described like this...
ID--> ID of each patient --> nominal
Age --> age of each patient --> integer
Test_i (i=1,..,4) -->score/grade of each test.--> ordinal--> [value ranges from 1,...,6, higher grade is more severe]
Class --> {cancer, not cancer) --> class of this dataset.
my question is, how to handle the attribute Test_i, it has ordinal data. Can I simply handle those attributes as integer or maybe I should handle those attribute as weights, or there are another ways?
my second question is about attribute weighting.
in that dataset, I use multiple attribute weighting technique, but i found that one out of 5 attribute resulted in 0 by normalizing weights and resulted in very much less value than other (e.g. the weight of this attribute is 0.00xx, the others is about >= 0.2xxx). Can I simply ignore that attribute?
Thank you very much for your reply.
best regards,
Dimas Yogatama
1 - 1 of 11
    User: "IngoRM"
    Hi,
    the answer depends a bit on the learning scheme you intend to (or have to) use. For example, let's say you want to model your problem with a linear regression scheme. In that case I would suggest to read the data as nominal (or transform them to nominal), transform the columns to binominal (Test_1 = 1 with values "true" and "false", Test_1 = 2 with values "true" and "false"...), and then to numerical (leading to 0 and 1). No the learning scheme can handle the fact that the values are ordered by assigning specific weights to each attribute - and hence to each of the ordered values. The same argument would of course also apply if the data is not ordered but simply nominal  ;)
    If the performance does not drop on an independent test set: yes.
    Cheers,
    Ingo
