🎉Community Raffle - Win $25
Join and Win
"Selecting out subset of data for Association Rule Mining."
User: "ckwcheng"
New Altair Community Member
Updated by Jocelyn
Here is a subset of my data that I'd like to use for association rule mining.  It is a semi-binary table
9762 CN14 0 0 0 0 0 0 1
9763 CN07 0 0 0 0 0 0 1
9764 CN07 0 0 0 0 0 0 1
9765 CN14 0 0 0 0 0 0 1
9766 CN14 0 0 0 0 0 0 1
9767 CN33 0 0 0 0 0 0 1
9768 CN02 0 0 0 0 0 0 1
9769 CN12 0 0 0 0 0 0 1
9770 CN14 0 0 0 0 0 0 1
9771 CN04 0 0 0 0 0 0 1
9772 CN04 0 0 0 0 0 0 1
9773 CN04 0 0 0 0 0 0 1
9774 CN05 0 0 0 0 0 0 1
9775 CN07 0 0 0 0 0 0 1
9776 CN07 0 0 0 0 0 0 1
9777 CN07 0 0 0 0 0 0 1
...etc.
I want to find out the association rules of CN07, CN14, etc individually.  That is, I want to find the association rules for just CN07, and then look at finding association rules for just CN14, and so on.   What data preprocessing step must I do in order to select out a subset to run through the association rule miner?  I'm using Rapidminer 5.
Any help is much appreciated!  Thanks!
1 - 1 of 11
    User: "land"
    Hi,
    you can use the filter examples operator to select a subset of the example set. If you want to automatically loop through all values of an attribute, you might take a look at the following process:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="565" width="963">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
          <operator activated="true" class="discretize_by_bins" expanded="true" height="94" name="Discretize" width="90" x="179" y="30">
            <parameter key="range_name_type" value="short"/>
          </operator>
          <operator activated="true" class="loop_values" expanded="true" height="76" name="Loop Values" width="90" x="313" y="30">
            <parameter key="attribute" value="att1"/>
              <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="30">
                <parameter key="condition_class" value="attribute_value_filter"/>
                <parameter key="parameter_string" value="att1=%{loop_value}"/>
              </operator>
              <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal to Binominal" width="90" x="179" y="30"/>
              <operator activated="true" class="materialize_data" expanded="true" height="76" name="Materialize Data" width="90" x="313" y="30"/>
              <operator activated="true" class="fp_growth" expanded="true" height="76" name="FP-Growth" width="90" x="447" y="30"/>
              <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/>
              <connect from_op="Filter Examples" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
              <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Materialize Data" to_port="example set input"/>
              <connect from_op="Materialize Data" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
              <connect from_op="FP-Growth" from_port="frequent sets" to_port="out 1"/>
              <portSpacing port="source_example set" spacing="0"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/>
          <connect from_op="Discretize" from_port="example set output" to_op="Loop Values" to_port="example set"/>
          <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Greetings,
      Sebastian
