<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="data_ver5_all.csv"/> <parameter key="label_name" value="CellCycle"/> </operator> <operator name="ExampleFilter" class="ExampleFilter" breakpoints="after"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label=anaA||label=anaB||label=prometa"/> </operator> <operator name="Normalization" class="Normalization"> </operator> <operator name="Random Optimizer" class="RandomOptimizer" expanded="yes"> <parameter key="iterations" value="100"/> <operator name="Xvalidation" class="XValidation" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="create_complete_model" value="true"/> <operator name="MetaCost" class="MetaCost" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="cost_matrix" value="[0.0 3.0 1.0;1.0 0.0 1.0;1.0 1.0 0.0]"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <list key="class_weights"> </list> </operator> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> <parameter key="create_view" value="true"/> </operator> <operator name="Performance (2)" class="Performance"> <parameter key="keep_example_set" value="true"/> </operator> </operator> </operator> <operator name="AverageBuilder" class="AverageBuilder"> </operator> <operator name="Performance (3)" class="Performance"> <parameter key="keep_example_set" value="true"/> </operator> <operator name="ProcessLog" class="ProcessLog"> <parameter key="filename" value="output_%{a}.log"/> <list key="log"> <parameter key="File" value="operator.CSVExampleSource.parameter.filename"/> <parameter key="Learner" value="operator.Classifier.parameter.select_which"/> <parameter key="Performance" value="operator.Xvalidation.value.performance"/> <parameter key="Deviation" value="operator.Xvalidation.value.deviation"/> <parameter key="Feature Selection On|Off" value="operator.FS SAM.parameter.enable"/> <parameter key="Pro_meta merging" value="operator.Class merging.parameter.enable"/> </list> <parameter key="sorting_dimension" value="3"/> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource" activated="no"> <parameter key="filename" value="data_ver5_all.csv"/> <parameter key="label_name" value="CellCycle"/> </operator> <operator name="ExampleFilter" class="ExampleFilter" breakpoints="after" activated="no"> <description text="This will not work - we've alreeady discussed why - wake up"/> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label=anaA||label=anaB||label=prometa"/> </operator> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="simple non linear classification"/> </operator> <operator name="Normalization" class="Normalization"> </operator> <operator name="Random Optimizer" class="RandomOptimizer" expanded="yes"> <parameter key="iterations" value="10"/> <operator name="Xvalidation" class="XValidation" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="create_complete_model" value="true"/> <operator name="MetaCost" class="MetaCost" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="cost_matrix" value="[0.0 3.0 1.0;1.0 0.0 1.0;1.0 1.0 0.0]"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <list key="class_weights"> </list> </operator> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> <parameter key="create_view" value="true"/> </operator> <operator name="Performance (2)" class="Performance"> <parameter key="keep_example_set" value="true"/> </operator> </operator> </operator> <operator name="AverageBuilder" class="AverageBuilder" activated="no"> </operator> <operator name="Performance (3)" class="Performance" activated="no"> <description text="Why on earth is this here? Disable it."/> <parameter key="keep_example_set" value="true"/> </operator> <operator name="ProcessLog" class="ProcessLog"> <parameter key="filename" value="output_%{a}.log"/> <list key="log"> <parameter key="File" value="operator.CSVExampleSource.parameter.filename"/> <parameter key="Performance" value="operator.Xvalidation.value.performance"/> <parameter key="Deviation" value="operator.Xvalidation.value.deviation"/> </list> <parameter key="sorting_dimension" value="3"/> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="I:\WORK\ver5\RM\DATA\data_ver5_all.csv"/> <parameter key="label_name" value="CellCycle"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <description text="This will not work - we've alreeady discussed why - wake up"/> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label=anaA||label=anaB||label=prometa"/> </operator> <operator name="Normalization" class="Normalization"> </operator> <operator name="Random Optimizer" class="RandomOptimizer" expanded="yes"> <parameter key="iterations" value="10"/> <operator name="Xvalidation" class="XValidation" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="create_complete_model" value="true"/> <operator name="MetaCost" class="MetaCost" expanded="yes"> <parameter key="keep_example_set" value="true"/> <parameter key="cost_matrix" value="[0.0 3.0 1.0;1.0 0.0 1.0;1.0 1.0 0.0]"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <list key="class_weights"> </list> </operator> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> <parameter key="create_view" value="true"/> </operator> <operator name="Performance (2)" class="Performance"> <parameter key="keep_example_set" value="true"/> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <parameter key="filename" value="output_%{a}.log"/> <list key="log"> <parameter key="File" value="operator.CSVExampleSource.parameter.filename"/> <parameter key="Performance" value="operator.Xvalidation.value.performance"/> <parameter key="Deviation" value="operator.Xvalidation.value.deviation"/> </list> <parameter key="sorting_dimension" value="3"/> </operator> </operator></operator>
