Model Import
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hey there,
I'm trying to import a leaf model I've generated. It was mostly created using the leaf wizard, and saved as a .mdl.
For some reason, every time I try to insert the model, whether just the data or data and wizard selections all I get is this:
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2017
    Also when I try to export...
    I have full admin rights and the file isn't read only or opened anywhere else?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2017
    Hi,
    Use Open file to open a .mdl file in MotionView.
    If you are using Student Edition 14.0, 2017, number of bodies are limited to 200 and it is not possible to export if the model has more than 200 bodies. n
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2017
    Hi,
    As my original post states, I am trying to IMPORT the model, not open. Full Hyperworks 2017
    After exporting from the .mdl generated using the leaf tool, upon trying to import into a half car model nothing happens.
    Am I trying to use this function incorrectly?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2017
    Hi,
    Click Model on Project browser and use Import option to import assembly/system...
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2017
    Right, but like I said, nothing seems to happen after this screen:
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2017
    Hi
    You are using File>>Import model option. What I am pointing is different.
    Click on Model in Project Browser>> Under model broswer properties>> Import/Export>> Import model.
    Please refer to the picture I shared.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2017
    Hi,
    I had the same error, but the answer from @Prakash Pagadala works, thanks a lot. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Kind Regards.
    Javier
Welcome!
Welcome!
