Creating Mesh: dest has 2 unmatche fixed points. Node associations my be wrong.
User: "Timo Ksr"
Altair Community Member
Updated by Timo Ksr
Hi,
When I create a SolidMap for one of my Solids it states in the left bottom corner:
'Waring: dest has 2 unmatche fixed points. Node associations my be wrong.'
And the outcome is this:
How can I fix this?
Thank you.
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    you can try using the 3D>>line drag
    create a shell mesh in your source and drag them though theline.
    or if it is a circular shape, use the 'spin' panel.
    User: "Timo Ksr"
    OP
    Updated by Timo Ksr
    Hi, Thanks for the quick response.
    This is just a cut out and actually there are kind of 'arms' attached to this solid, whose mesh has to be considered.
    Line Drag or Spin would just create the mesh I believe. Thats why I am trying to fix this instead of creating a simple new mesh.
    Thanks.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Share your model?
