🎉Community Raffle - Win $25
Join and Win
Rapidminer 4.4 -> 4.5. Will upgrade retain files?
User: "ruser"
New Altair Community Member
Updated by Jocelyn
While working with the Rapidminer v4.4, I got the notification that Rapidminer new version v4.5 is available.
I'm just wondering whether the direct upgrade from v4.4 to v4.5 is possible, or I have to reinstall the Rapidminer with the new version.
How do I retain the process and data files which were created with the Rapidminer v4.4?
1 - 3 of 31
    User: "land"
    Hi,
    you have to download and install the new version. The process and data files are fully compatible with the new version. Only some IO objects might cause trouble, but we haven't noticed so far...
    Greetings,
      Sebastian
    User: "ruser"
    OP
    Thanks. But, the question precisely is whether the new installation override the folders containing the process and data files, in case if I have kept under the Rapidminer installation directory.
    I can copy such files before the installation, and restore them back once the installation is completed. But, I would like to know the actual behaviour during the upgrade.
    User: "land"
    Hi,
    unfortunately the uninstaller will delete every file below in the old rapid miner directory...
    So if you save your data in the program directory, you have to coipy it into another location.
    Greetings,
      Sebastian
