Nodal boundary condition error
Lea
Lea Altair Community Member
edited November 2023 in Community Q&A
Hello,
I am trying to apply nodal boundary conditions with scattered data. The goal is to split one large model into two seprerate ones and use the outflow of the first one as inflow for the second model. Since the velocity profile is complex, I extracted the velocity data from the output to a csv file and now want to use this data as nodal boundary condition for the second half of the model. This however leads to the following error (same for all conditions):
NODAL_BOUNDARY_CONDITION( "Advanced - z_velocity" )
acuPrep: *** ERROR: Scattered data is non-planar
Since it is only possible to include scattered date with xyz-coordinates, I am wondering how this data is supposted to be planar?
Thank you in advance!
Lea
Welcome!
Best Answer
  • acupro
    acupro
    Altair Employee
    edited November 2023 Answer ✓
    The data (source and target) need to be planar.  So for example, a planar outlet mapped to a planar inlet.  Best to use the   acuGetNodeSubset   script to extract the data from the planar outlet, to then arrange for the planar inlet with the NBC.   acuGetNodeSubset -h    for usage
Answers
  • acupro
    acupro
    Altair Employee
  • Lea
    Thank you, it worked!
    one more question: I read in another post that you should always use an nodal boundary condition with a simple boundary condition. How does that work? Right now I only use a nbc for pressure, velocity, eddy frequency, eddy viscosity and kinetic energy. The simulation runs smoothly but my results are not as they supposted to be. Could this be the reason? Did I miss any parameters that are requiered for nbc to work as inflow?
    Thanks again
    Lea
  • acupro
    acupro
    Altair Employee
    Thanks again
    Lea
    I would recommend not using the Pressure NBC at the inlet - as then you've specified both velocity and pressure which is over-specification.  Instead, I would add Element BCs for both the pressure and tangential_traction variables, with type = free.
    That is the benefit to using a Simple BC - that takes care of all the details in the background, as Simple BC is really a combination NBCs and EBCs - then add NBCs with a higher precedence, say 2, to handle what you want to explicitly set.  It may be easier to use Simple BC with a velocity inflow type - then add your desired NBCs - but still not for pressure.  Let the inlet pressure be calculated from the solution, to be consistent with the outlet.
  • Lea
    Thank you, that was very helpful! The results look much better now that I added an EBC for pressure instead of a NBC.
Welcome!
Welcome!
