Altair RISE
Nominate Yourself Now!
Hypermorph radius and rotate
User: "realbak"
Altair Community Member
Updated by realbak
Hi,
I give the radius value in the corners, and the component direction separately as shapes.
I will use these shapes as DOE in Hyperstudy.
But when I change the two shapes at the same time, a useless shape like the one in figure 'radiusandrotatecombined' appears.
How can I design a proper shape by correcting this situation?
Thank you,
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Since the part is symmetric apply one plane symmetry in your model .First shape seems to be ok but why you are rotating all handle in second shape?
    User: "realbak"
    OP
    Updated by realbak
    Yes, symmetry can be applied in the model. This model is a section fo the twistbeam and I want to see deformations of the beam I when to apply moments opposite direction. And I want to see effects of the orientation of the beam.
    User: "realbak"
    OP
    Updated by realbak
    Dear Rahul,
    I understood the source of the problem. The problem is that shape vectors move linearly. As you can see, it is true when the shape multiplier is 1, but when I define the shape multiplier as 3, the shape is wrong. The handles of the part move along the shape vectors instead of rotating around the center. I think I can solve this problem if I can define shape vectors as cylindrical instead of linear. Finally, how can I define the shape vector cylindrical?
    <?xml version="1.0" encoding="UTF-8"?>2008899512_2019-06-1912_37_45-Sunu1-PowerPoint.thumb.png.9fe8145df3dd891993790f040ef009c9.pngI
