Altair RISE
Nominate Yourself Now!
Not enough memory available on the hard disk
Hi everyone, I'm trying to develop a resonance study including a patch GPS antenna and when I try to run the FEKO solver it says all segments and triangles are perfectly conducting. After checking geometry and mesh the 'ERROR 33238: Not enough memory available on the hard disk for an out-of-core file' appears. The .out file describes 244340 flat triangles and my computer has 64GB RAM installed (below you can find the .out file). I allowed also a local parallel execution, but the error stills appearing.
I'm using the default solver (MoM), but I don´t know if I'm using a wrong solver. Since my geometry is approx. 83x180mm.
Should I use the 'farm out' function as well?
Thanks.
1 - 5 of 51
