🎉Community Raffle - Win $25
Join and Win
"Running an xml process file with the API"
emolanoUser: "emolano"
New Altair Community Member
Updated by Jocelyn
Hi there,
I have an xml process file. It runs fine with the rapidminer GUI. Is it possible to run it from a java application using the API?
I know one could be rewrite the process using the API
something like  inputOperator = OperatorService.createOperator("DatabaseExampleSource");
      // set parameters
      inputOperator.setParameter("database_system", "MySQL"); ...
but I just want to run my existing xml process file within an eclipse project.
Thanks. Help is appreciated.
1 - 2 of 21
    Hello emolano
    I assume you have read chapter 7 of the tutorial.pdf.
    The requested can be perform like this:
    File processFile = new File("d:/test.xml");
    if (!processFile.exists()){throw new Exception("File '" + processFile.getAbsolutePath()+ "' does not exist!");}
    Process process = RapidMiner.readProcessFile(processFile);
    IOContainer input = new IOContainer();
    IOContainer output = process.run(input);
    hope this was helpful
    regards,
    Steffen
    OP
    Thanks. It woks fine.
    Here my code with the init part:
    import java.io.File;
    import com.rapidminer.Process;
    import com.rapidminer.RapidMiner;
    import com.rapidminer.operator.*;
    public class executeXMLModel {
      public static void main(String[] argv) throws Exception {
      String modelFile="C:/Documents and Settings/emolano/My Documents/rm_workspace/mining/platform/xmlModel.xml";
      // set properties to point to plugin directory
          String pluginDirString = new File("C:\\Program_Files\\Rapid-I\\RapidMiner\\lib\\plugins").getAbsolutePath();
          System.setProperty(RapidMiner.PROPERTY_RAPIDMINER_INIT_PLUGINS_LOCATION, pluginDirString);
          // set properties - rapid miner home
          String path="C:\\Program Files\\Rapid-I\\RapidMiner\\";
      System.setProperty("rapidminer.home",path );
          // initialization
      RapidMiner.init(false, true, true, true);
      File processFile = new File(modelFile);
