Altair RISE
Nominate Yourself Now!
PTCV advanced joint
User: "jillukevin"
Altair Community Member
Updated by jillukevin
I have done this ptcv joint tutorial in motionview 10 but it is not working in MV 12.I have carefully followed all instructions but it gives error saying entity b02 empty in advanced joint even though i have selected the marker and curve for body 2. Thank you for answers
1 - 9 of 91
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    HI,
    Have you tried modelling the same in V 12.0?
    can you share the model with us?
    User: "jillukevin"
    OP
    yes i have tried it in 10 its working but in 12 its not working .ill share the file in ur drop box ,thank u
    Altair Employee
    Hi,
    Thanks for sharing the file. I will look into this and get back to you ASAP!!
    Altair Employee
    HI,
    I am able to run the analysis at my end with 12.0 and no modifications are done for the model.
    Can you share a screen shot of the error you get at your end?
    User: "jillukevin"
    OP
    Ok i will share the pic, thank you
    User: "jillukevin"
    OP
    This is the screen shot for which I get an error<?xml version="1.0" encoding="UTF-8"?>post-34208-0-72397500-1428685745_thumb.j
    Altair Employee
    Hi,
    In Advanced joint you have used, check if the body-2 is referring to Cam or not as shown in the picture.
    some how, in your model the for Advanced joint body 2 no 'body' is referred or taken,
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-87040100-1428896287_thumb.jp
    User: "jillukevin"
    OP
    Yes sir I have the body in body 2 tab here is my screen shot
    <?xml version="1.0" encoding="UTF-8"?>post-34208-0-44675600-1429026920_thumb.j
    Altair Employee
    Hi,
    The file you shared with me is running fine at my end ( I hope this is the same file you are using).
    Could you please let me know what are the updates you have?
    You can find the software updates and graphics information from HyperMesh>> Help>> Updates and system information
    http://forum.altairh...n-your-machine/
