🎉Community Raffle - Win $25
Join and Win
Can not find AttributeSumClusterCharacterizer Node
User: "Legacy User"
New Altair Community Member
Updated by Jocelyn
in Text-mining AttributeSumClusterCharacterizer Node can not be found with 4.3 version.
Is it replaced by other Node? how can I to solve this problem
1 - 3 of 31
    User: "land"
    Hi,
    since version 4.3 the cluster characterizer has been removed, since its easyly possible to use any learning algorithm to characterise your clusters. I will post a simple example process below:
    <operator name="Root" class="Process" expanded="yes">
        <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
            <parameter key="number_of_attributes" value="2"/>
            <parameter key="target_function" value="gaussian mixture clusters"/>
        </operator>
        <operator name="KMeans" class="KMeans">
            <parameter key="k" value="3"/>
        </operator>
        <operator name="ChangeAttributeRole" class="ChangeAttributeRole">
            <parameter key="name" value="cluster"/>
            <parameter key="target_role" value="label"/>
        </operator>
        <operator name="RuleLearner" class="RuleLearner">
        </operator>
    </operator>
    Hope this helps.
    Greeting,
      Sebastian
    User: "Legacy User"
    OP
    Hi, I have tried it. thank you.
    As a beginner, I have still a question.
    In old AttributeSumClusterCharacterizer node, it provides the visibility of showing N words that represent every cluster.
    How can I do it now?
    May it is not so clear, but its a shame that I didn't save the old pictures of the analysis
    e.g. old AttributeSumClusterCharacterizer node reults in Text view
    Cluster Model
    Cluster 0 [xxx, swe, ower]: 6 items
    Cluster 1 [soliw, wo, sow]: 2 items
    Cluster 2 [wepoi, soawer, aowe]: 4 items
    Cluster 3 [aoiwer,aiwoer ioser]: 2 items
    Total number of items: 14
    but now
    Cluster Model
    Cluster 0: 6 items
    Cluster 1: 2 items
    Cluster 2: 4 items
    Cluster 3: 2 items
    And I find the processing time is rahter long for RuleLearner.
    How can I get the Characteristic words now?
    User: "Legacy User"
    OP
    During the processing, I get two Warnings, Why?  :-\
    P Dec 2, 2009 1:41:03 PM: TextInput: Creating WVTool input list from parameter list (ignoring input example set if any).
    P Dec 2, 2009 1:41:06 PM: TextInput: Total number of words is 6485
    P Dec 2, 2009 1:41:06 PM: [Warning] TextInput: The original example example set already contains an attribute named "label". This is likely to cause trouble. Please rename the attribute in the original example set.
    P Dec 2, 2009 1:41:06 PM: [Warning] TextInput: There is a term that equals the class attribute, renaming it
