Altair RISE
Nominate Yourself Now!
RCS of Target Using Only PO
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello Every Body,
How configure FEKO in Solver Setting in order to use only Pysical Optics(PO) to calculate RCS?
Thanks
1 - 2 of 21
    User: "JIF"
    Altair Employee
    Updated by JIF
    Hello Zenki,
    PO is a face solution property. Thus, you don't need to make any changes in the Solver Settings dialog. Simply select all the faces in the model, right click and select Properties. Then go to the Solution tab and select the PO option that you want to use. Once you apply the setting on the faces, they will be solved using PO.
    Altair Employee
    OP
    Thank you very much
