How to find a Quad with only 3 nodes under hypermesh
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
I would like to know the method to detect a quad with only 3 nodes (instead of triangle definition)  that can create problem under another software like Ansys (shell181) : QUAD N : Node1 Node2 Node3 Node(1 or 3) for example
thank you for your help
patrick
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited March 2018
    Hi,
    if the quads have 2 nodes sharing same position, they will have minsize = 0, so please check F10>min length 0 (set calculation as 'shortest edge'), you will catch the quads
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    edited March 2018
    Hello,
    From my understanding, quads are 2D elements with 4 nodes. The element will be a tria when there are only 3 nodes. You can find a element based on their configuration i.e. tria or quad in HM by using 'by config' in the selector.
    Thankyou
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited March 2018
    This kind of quad has very bad Jacobian.
  • tinh
    edited March 2018
    Yes, it's bad. I heard from my teacher that this degenerated quad is used for crack simulation
Welcome!
Welcome!
