🎉Community Raffle - Win $25
Join and Win
"Filtering Multiple Attributes"
User: "hgwelec"
New Altair Community Member
Updated by Jocelyn
Hello,
Suppose we have a dataset with the following attributes
Age
Profession
Income
NumberOfChildren
class
How can i remove from analysis , attributes "Age" and "Profession" without using multiple operators (ie two AttributeFilter operators). If it can be done could someone give me an example?
Many Thanks
Harry
1 - 3 of 31
    User: "haddock"
    Bonjour!
    Try using the operator "FeatureNameFilter" and use  "Age|Profession" as the value for the parameter "skip_features_with_name"
    Actually there is probably a much more cryptic regex that will also do the job, but I'm too lazy to work it out....
    Allez!
    User: "hgwelec"
    OP
    Found it :
    Use a FeatureNameFilter operator and write the following on the'skip_features_with_name' field :
    (Age|Profession)
    User: "hgwelec"
    OP
    Thanks!!  :)
