1 - 5 of
51
Nope
As far as I see the following method TTestSignificanceTestOperator#getProbability(PerformanceCriterion pc1, PerformanceCriterion pc2) calculates the p-value of the test. The test itself is ''performed'' here:
TTestSignificanceTestOperator#TTestSignificanceTestResult#toString() , i.e. here:
this is the used formula:
http://en.wikipedia.org/wiki/Student';s_t-test#Unequal_sample_sizes.2C_equal_variance => two-sided-test
BUT looking at this formula raises another questions:
First: I have read somewhere that the assumption of equal variances is not a problem if the sizes of the test samples are equal. On the other hand, if this is not valid, no one can guarantee anything for the true alpha error. What do you think about it?
Second:
I thought in case of a two-sided test the alpha parameter must be divided by 2. Or is this already implied by the test statistics ?
greetings
Steffen
PS:
result.append("Values smaller than alpha=" + Tools.formatNumber(alpha) + " indicate a probably significant difference between the mean values!" + Tools.getLineSeparator());the comparison of pvalue < alpha is no clear indication for a left-sided test...
Second:
greetings
Steffen
PS:
I prefer such argumentations with class names and line numbers
Username wrote:
I looked at the source code and it does look like a left sided test, doesn't it?
Hello again
I guess everything is clear now
greetings
Steffen
steffen wrote:
Second:
I checked it and found that it is ok that alpha is not divided. You can see the t-test as a special case of ANOVA with two groups. In this case t=sqrt(F) (regarding the teststatistics). The F-teststatistics is tested again the 1-alpha-quantile for the same hypothesis, so ...
Username wrote:
That's why I guessd it's a one sided test.
greetings
Steffen
the description says: so I say it is a both-sided test with H0: mu1=mu2, H1: mu1!=mu2
greetings
Steffen
