1. If you mean the properties of the generated model: If you saved it in an xml-file (slow) than you can look at the properties with a simple text editor. Either ways you can reload the model in RapidMiner using ModelLoader to look at the provided model-view (depending on the kind of model) 2. If you mean the parameters you have set to create the model: As far as I see, this information is only available within the corresponding process-file
I am not sure if I got you right, sooo...
hope this was helpful
Steffen
