🎉Community Raffle - Win $25
Join and Win
Remove 3D elements free edges
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I know someone has asked this topic before. However, all the solution I found did not work on my case.
I used 'edges' to find the free edges between two hex elements.  I have tried to remove it by ' equivalence ' and by deleting the elements and creating them again. When I checked the nodes on the two hex elements. I found that there is one shared node has two ID numbers. So I also tried to replace one ID with another ID. None all these methods worked.
Please help me.
Thank you very much!
1 - 9 of 91
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi jacobier
    The Edges panel functionality applies only for 2D shell elements
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.5c8e06d12e333ab5073c61260c1a6007.png
    Similar connectivity check for 3D elements can be done only in faces panel ( Tools > faces )
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f8ad3b137058e849f8d220bb9a49b4c8.png
    Altair Employee
    OP
    So does it mean that I don't need to worry about the free edge for my case?
    Altair Employee
    OP
    Actually when I used 'face' function. I found a face between the two elements. 'Equivelance'  did not work as well.
    User: "tinh"
    Updated by tinh
    Could you show a photo?
    I checked your file but don't see it
    Altair Employee
    OP
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.51b8acf55c06212aa89ccd3f859cfc17.png
    The other edges are correct. Only these two are related to connection and should be removed.
    User: "Mario_21478"
    Updated by Mario_21478
    Hello jacobier,
    The left of the two masked (hidden) elements (yellow, Reissner's membrane) is at fault.
    It's a degenerate hexa element, rather than a penta. Therefore, at this point, the nodes can not become equivalence.
    Best Regards,
    Mario
    Altair Employee
    OP
    Hi, Mario
    Thank you very much! How can I solve this? I have tried deleting the element and manually making penta element, but the problem remained.
    User: "Mario_21478"
    Hello jacobier,
    Delete the element and make a equivalence check (display all before).
    Then you can create a new one.
    Best Regards,
    Mario
    Altair Employee
    OP
    After I deleted the elements and displayed all, still 0 nodes were found for equivalence. Can you try that for me, as I have uploaded the model.
