"Horizon value in Sliding Window Validation"
I'm trying to predict currency values from indicators, on a daily basis. Each daily example has a Label expressed as the change in the currency over the next N days, a date as an ID, and numeric attributes.
Validation is done use the Sliding Window Validation operator. While most of the parameters are self-explanatory I am having difficulties with the "horizon" parameter whose definition is as follows
"Number of examples which are between the training and testing examples (integer; 1-+Infinity; default: 1)"
At a trivial level, if I break before the learner and break before the applier operators in the validation, I can see that when horizon is set to 1 the validation starts on the next example after the training set, meaning that there are in fact 0 examples between the training and testing examples. No big deal, just thought I'd point it out.
My question is whether I should use 1 as the parameter for horizon, or whether horizon should reflect the forecast period, such that if the prediction is for 10 days, horizon should be set to 9. I can see arguments on either side, so appeal to wiser minds for guidance..
1 - 3 of
31
Nice one Ingo!
I'd taken that approach, setting horizon to 1 when it should be say 20 gives a rough proxy for training performance only! On the definition front perhaps this is clearer.
"Increment from last training to first testing example (integer; 1-+Infinity; default: 1=next example)"
Thanks again for your clarification.
Hope that helps. Cheers,
Ingo
