"Bug in Feature Generation: side effects"
Hello RapidMiner Team
I am using the latest cvs-version and tried to implement the ZTransformation. That means, calculating mean and std from input ExampleSet and then apply a series of RM-Operators, calling them within my code. Trying some preprocessing steps before my operator, I stepped over the strange behaviour of the FeatureGenerationOperator, which I also use. Then I simulated the Code in a process, using only RM-builtin-Operator. The strange things happened again. Two notes regarding the following setups:
Hope this error-desription was somehow helpful
greetings
Steffen
- The "useless" re-naming I got to perform because (originally) I wanted to use an attributenname containing a "(" within FeatureGeneration (confidence...)
- In the following setups I used the dataset described by golf.aml delivered with the RM-distribution.
2. But accidently using the wrong attributename within FeatureGeneration, no error message appeared, but this wrong result.
<operator name="Root" class="Process" expanded="yes">
<operator name="ExampleSource" class="ExampleSource">
<parameter key="attributes" value="golf.aml"/>
</operator>
<operator name="Temperature->ijon" class="ChangeAttributeName">
<parameter key="new_name" value="ijon"/>
<parameter key="old_name" value="Temperature"/>
</operator>
<operator name="apply_ztrans" class="FeatureGeneration">
<list key="functions">
<parameter key="tichy" value="/(-(ijon,const[73.571]()),const[6.3326]())"/>
</list>
<parameter key="keep_all" value="true"/>
</operator>
<operator name="skip_ijon" class="FeatureNameFilter">
<parameter key="filter_special_features" value="true"/>
<parameter key="skip_features_with_name" value="ijon"/>
</operator>
<operator name="tichy->Temperature" class="ChangeAttributeName">
<parameter key="new_name" value="Temperature"/>
<parameter key="old_name" value="tichy"/>
</operator>
</operator>
3. Setting the correct names, but applying the Sorting-Operator before causes the same results as in step 2.
</operator>
</operator>
<parameter key="tichy" value="/(-(Temperature,const[73.571]()),const[6.3326]())"/>
</list>
</operator>
</operator>
</operator>
</operator>
At this point I came to the conclusion, that the problem must lurk deeply in the RapidMiner entrails ...
</operator>
<operator name="sort_temperature" class="Sorting">
<parameter key="attribute_name" value="Temperature"/>
</operator>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
greetings
Steffen
