Altair RISE
Nominate Yourself Now!
Visualize resultant force vector of a node
User: "rea2"
Altair Community Member
Updated by rea2
I have a moving rigid body and 3 concentrated loads (one each for x,y,z) on its master node. Besides, I have an output block for REACX, REACY and REACZ for this node and I'm able to plot the forces for that node in Hypergraph. However, what I'd like to do is visualizing the resultant force vector in Hyperview, as an arrow/vector in real time during the movement, to determine whether the resultant points in the desired direction. Is there a way to do this?
I use Hypermesh & Radioss.
1 - 6 of 61
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi rea2
    You can check this option in Hyperview
    Select vector option and set the result type to forces.
    select the rigid body component and click apply. This will show the resultant vector value and direction in real time.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f773406fad5cad34976a53dcd7c2034a.png
    User: "rea2"
    OP
    Updated by rea2
    Hi rea2
    Thank you so much! That's what I also found, but I only have displacement as a possible result type, no contact forces. I also exported Von Mises, Pressure and Energy as a result type, but they are not available there (probably since they are not vectors?). How do I get contact forces? I don't find it as an option in the ENG_ANIM_ELEM card.
    User: "Pranav Hari"
    Hi rea2
    Go to Analysis > control cards > click next and select ENG_ANIM_VECT
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.75ec610f6bd1aaa752914a96d4549334.png
    select ENG_ANIM_VECT and then tick on CONT for contact forces.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.2d77fd9db54fb34a10367a7f2bf8d0d5.png
    User: "rea2"
    OP
    Updated by rea2
    Hi rea2
    Thank you! I was able export the forces but couldn't visualize the vector on the master node yet. Still trying - but thank you for your help!
    User: "Pranav Hari"
    Hi
    If possible please share the .h3D file. i will also have a try
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    So is this possible with an LS-Dyna input file?
