I get the error Message "Error Loading file o1_120lbs.stp. See ct_reader.msg file for details".
Where is the ct_reader.msg file ?
Why can't I find the answer to this in you VERY USLESS help system?
It's in your start in directory.
by default located here: %USERPROFILE%\Documents
I found the file. Lots of information I do not understand. Then says “Can’t open file” what does that mean?
checked permissions and HyperMesh has permission to read the file.
If the format incompatible?
Is the geometry incompatible?
