🎉Community Raffle - Win $25
Join and Win
EDEM Tutorials
User: "Stephen Cole"
Altair Employee
Updated by Stephen Cole
Below you can find links and details about Altair® EDEM™ tutorials and scripts on Altair Community
If you are new to the Discrete Element Method, we have e-learning and online training sessions in addition to the Altair How-To YouTube series.
Introductory tutorials designed to give familiarity to the EDEM user interface, creating materials and importing CAD
  1. EDEM Conveyor example, introducing particle shapes and conveyor kinematic
  2. EDEM Screw Auger example, introducing material to rotating geometry
  3. Rock Box using Mixed Shape Solver (Polyhedral + Spheres)
Tutorials outlining the different physics models in EDEM
  1. Tavares Breakage for SAG Mill
  2. Learn how to use the Linear Elastic Bonded Model model for solids and soft soils
  3. How to use the 1-way coupling to introduce a flow field and calculate Lift and Drag forces
  4. Printer based tutorial for Electrostatics and Tribocharging
  5. How to use the Edinburgh Elasto-Plastic Adhesion model and the Hysteretic spring for Tablet Press simulations
  6. How to model conductive Heat Transfer with DEM
For Heat Transfer you can customise the physics, for example, to include geometry as a heat source.  For the 1-way coupling you can also customise the physics as shown here and here, or for coupling EDEM to AcuSolve either 1-way (Unidirectional) or 2-way including heat and mass transfer, the tutorials are here:
Tutorials for different EDEM Applications
  1. How to use the bonded particle model to generate flexible materials for cutting (e.g. mowers and grass cutting)
  2. Using Spherocylinders with bonds for flexible materials
  3. Model a transfer chute with the discrete element method and introduce cohesive materials with the JKR model
  4. How to setup a Slatted Conveyor belt in EDEM
  5. How to model Mixing in a Tablet Coater, focussing on the post-processing
  6. EDEM Application Tutorial EDEM 3000: Dozer Blade with Dynamic Domain
Or if using EDEM BulkSim we have transfer chute and material modeler tutorials for this, note EDEM BulkSim is now unsupported.
For custom EDEMpy custom analysis you can get started here:
There are lots of EDEMpy examples on Altair Community, for example:
You can also benefit from the knowledge of experienced EDEM users. We have a series of webinars presented and recorded for on-demand viewing, you can see the EDEM Webinars here:
And more presentations from ATCx Discrete Element Method 2022
Material Calibration and Advanced functionality
To start with EDEM calibration please see the e-learning materials:
Or our blog:
Some further details on how to use EDEM Batch Mode:
For Calibration of EDEM results with Hyperstudy you can use the Hyperstudy-EDEM link:
Also
EDEM Multi-Physics Tutorials
  1. EDEM + Hypermesh for FEA analysis of DEM results. Using Optistruct with EDEM
  2. Use SimSolid with EDEM for structural analysis
  3. Optimizing Dynamic Systems Interacting with Particulate Materials : EDEM-MotionSolve
    1. Couple MotionSolve with EDEM
  4. Introduction to CFD-DEM for modelling fluid-particle systems
    1. AcuSolve EDEM Tutorials
For 3rd party couplings
  1. EDEM- RecurDyn Quick Start Guide
  2. EDEM Tutorial: EDEM-RecurDyn - Simulating the Brazil nut effect
  3. EDEM-OpenFoam Coupling
  4. EDEM - Adams Tutorial - Screw Propeller
  5. EDEM-Fluent Tutorials
How to customise EDEM with the API
  1. EDEM API 4000 API Introduction - Particle Replacement
  2. EDEM API 4100 Variable Cohesion
  3. EDEM API 4200 Field Data
  4. EDEM API Tutorial : Relative Wear Analysis
  5. EDEM API Tutorial: Debugging (Snooker Factory)
  6. EDEM API Tutorial: Hertz-Mindlin with Pressure Calculation
GPU Guide (
  1. EDEM CUDA API Tutorial 1: CPU API to CUDA API Conversion
  2. EDEM CUDA API Tutorial 2: CUDA Custom Properties and Parameters
If you are looking for further information on EDEM we have plenty more on Altair Community:
Altair Community EDEM
EDEM API Webinar
1 - 3 of 31
