My second line of toolbar which contain visualization icon with all other icons is missing.
I tried the view option but the whole second line is missing.
What to do?
Hi Shivang,
Please delete the settings files and try opening HyperMesh and let us know the outcome.
After doing this also I am getting the same problem
I am attaching the screenshot in which the bar is missing
Hi
You have to close hypermesh before delete hmsettings.tcl and hmmenu.set
Hello Sir
I have done the same but still having the problem.I couldn't find the hmsettings.tcl and hmmenu.set but deleted .altair folder.
Kindly guide through a solution.
Please check your working directory (normally Documents folder) and delete all .tcl and .set files.
And please make sure that the option is checked in the Toolbars menu.
Still having the problem.
Tell me some other path to open visualization bar and shaded geometry and free edges icon.
If you did not see hmsettings.tcl or hmmenu.set files
Click on menu View>Command Window
then type in the command window below command:
pwd
it show current working directory, just copy it and paste to window explorer
remember to quit hypermesh before deleting those 2 files
Hello,
I missed options ( Geo, 1D, 2D,...) in the right side of the Hypermesh ( as you can see in the attached picture). what should I do to return them.
I appreciate your help.
Sara
Did you try deleting the settings file?
If yes and it is still not working please let me know!
This is how you delete the settings file:
Thankyou
Hello, Did you try deleting the settings file? If yes and it is still not working please let me know! This is how you delete the settings file: Thankyou
Hi,
In the location I had just hmmenu.set I deleted it but now when I open Hypermesh, it said that the menu file ''hmmenu.set'' was not found:(
best,
sara
Can you please check that you are updated with the latest hotfix and you are using the latest version.
If you are and this is still not showing, i would advice you to please reinstall HW.
Hello, Can you please check that you are updated with the latest hotfix and you are using the latest version. If you are and this is still not showing, i would advice you to please reinstall HW. Thankyou
Thank you Sanjay. I updated it and it fixed.
Best Regards,
Hello Sir I missed options (page layout ) on toolbar .which helps to split the window into two to solve model in radioss . What should I do to return them .. Kindly guide through a solution.
