Altair RISE
Nominate Yourself Now!
Toolbar Missing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
My second line of toolbar which contain visualization icon with all other icons is missing.
I tried the view option but the whole second line is missing.
What to do?
1 - 13 of 131
    Altair Employee
    OP
    Hi Shivang,
    Please delete the settings files and try opening HyperMesh and let us know the outcome.
    Altair Employee
    OP
    After doing this also I am getting the same problem
    I am attaching the screenshot in which the bar is missing
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    You have to close hypermesh before delete hmsettings.tcl and hmmenu.set
    Altair Employee
    OP
    Hello Sir
    I have done the same but still having the problem.I couldn't find the hmsettings.tcl and hmmenu.set but deleted .altair folder.
    Kindly guide through a solution.
    Altair Employee
    OP
    Hi Shivang,
    Please check your working directory (normally Documents folder)  and delete all .tcl and .set files.
    And please make sure that the option is checked in the Toolbars menu.
    Altair Employee
    OP
    Hello Sir
    Still having the problem.
    Tell me some other path to open visualization bar and shaded geometry and free edges icon.
    User: "tinh"
    Updated by tinh
    If you did not see hmsettings.tcl or hmmenu.set files
    Click on menu View>Command Window
    then type in the command window below command:
     pwd
    it show current working directory, just copy it and paste to window explorer
    remember to quit hypermesh before deleting those 2 files
    Altair Employee
    OP
    Hello,
    I missed options ( Geo, 1D, 2D,...) in the right side of the Hypermesh ( as you can see in the attached picture). what should I do to return them.
    I appreciate your help.
    Sara
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    Did you try deleting the settings file?
    If yes and it is still not working please let me know!
    This is how you delete the settings file:
    Thankyou
    Altair Employee
    OP
    Hello,
    Thankyou
    Hi,
    In the location I had just  hmmenu.set I deleted it but now when I open Hypermesh, it said that the menu file ''hmmenu.set'' was not found:(
    best,
    sara
    Hello,
    Can you please check that you are updated with the latest hotfix and you are using the latest version.
    If you are and this is still not showing, i would advice you to please reinstall HW.
    Thankyou
    Altair Employee
    OP
    Hello,
    Thankyou
    Thank you Sanjay. I updated it and it fixed.
    Best Regards,
    Sara
    Altair Employee
    OP
    Hello Sir
    I missed options (page layout ) on toolbar .which helps to split the window into two to solve model in radioss .
    What should I do to return them ..
