Hello everybody
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
one question to hyperview:
I connected 45 nodes to a node-set. This node set describes the circumference of a certain body. Is it possible to write out a contour plot of this node-set, only of this node-set?
At the end I want to describe the contour before and after simulation. I work with LS Dyna.
Regards,
ChiaBr
