1 - 14 of
141
Hi Gopal.
Yes, it acts a scaling factor. Maybe you can test it your self with the attached model.
Hi Gopal.
I made a similar file to check for scale factor functioning.
It is not working in the attached file for me and not able to find where I am doing the mistake
Thank you
In your model, you are applying a prescribed displacement which may not show the effect of the K.
Can you try with force as the load?
Kindly rply
