Hello All,
I am starting to analysis of the component, Please share the procedure of the fatigue analysis of any component, and also can we find the life of the component based on its fatigue analysis?
Thanks
Hi,
Please refer to below tutorials on Fatigue
how to peform fatigue analysis in radioss ?
In RADIOSS its not possible to perform a fatigue analysis. You can use OptiStruct for the same.
sir my loading is of short duration then how to perform fatigue analysis for the same ?
How much is the short duration for the loading?. Since fatigue is failure under a repeated load the duration will be more for a fatigue analysis.
miliseconds .
Fatigue failure will not happen in milliseconds time. In milliseconds, normally it will be a crash/impact analysis.
if my loading is in millisecond ?
As mentioned before, a failure that can happen in milliseconds is a crash/impact case.
Please elaborate on your analysis objective so that we can guide you.
a steel beam with cyclic load with loading time in the millisecond?
We have tutorials in Help on fatigue analysis (OS-1340). Please go through the same and try solving with this time duration.
What are material properties required for the fatigue analysis in HyperWorks?
I'm sharing a tutorial. Please review the same which shows the required material cards for fatigue analysis.
thanks...george ..for sharing tutorial.
Anyone could share me video link or upload the file.
