Export Time Domain results using lua script
Hi,
I have a time-domain excitation pulse (generated using Matlab as a .txt file). this excitation needs to be imported to PostFeko, calculate the time domain voltage across the load (in postfeko), then export the TD voltage to .dat or .txt file. I need to run all of this through Lua script. If I can do so then instead of reopening postFEKo every time I change the excitation pulse I can run the script through Matlab.
I have attached a basic Lua script that reads the current across the load and exports the data to the .dat file. However, it exports the Frequency domain data, not the Time domain. I have a very very basic knowledge of LUA scripting. I would really appreciate it If anyone has an idea of how to modify the script to perform the above tasks.
attached the FEKo Files and the Lua script.
You could use ExportTraces:
graph=app.CartesianGraphs[1]
graph:ExportTraces("mydata.txt",101)
