Exporting currents on each triangle
I would like to export current values on each triangle. I can visually see the current density on POSTFEKO but values are not written to .out file. On the .out file, there is a table for the current values but it is empty. The screenshot for the .out file is attached.
As the Note 32958 states, for HOBF, the output of currents and charges are not supported.
