Exporting currents on each triangle
User: "hykr"
Altair Community Member
Updated by hykr
I would like to export current values on each triangle. I can visually see the current density on POSTFEKO but values are not written to .out file. On the .out file, there is a table for the current values but it is empty. The screenshot for the .out file is attached.
1 - 2 of 21
    User: "Mel"
    Altair Employee
    Updated by Mel
    As the Note 32958 states, for HOBF, the output of currents and charges are not supported.
    User: "hykr"
    OP
    Updated by hykr
    Thank you for the prompt response. The problem is solved when HOBF option is unselected.
