Hi,
what is the procedure to define pin hinge with torsion spring in Radioss with similar functionality as in Motionsolve?
In the file attached bellow I have modeled continuous pin (piano) hinge through type 2 contact with spotflag=4. This works great except there is no option to define small translational compliance (play in the hinge) or joint friction. The other option is to define the hinge through Kjoint2 spring, which requires rigid body on adjacent elements that adds artificial stiffness.
How can torsion spring with rotational stiffness, damping, free angle and preload be added on pin joints?
