🎉Community Raffle - Win $25
Join and Win
select nodes by csys
User: "evsm1982"
Altair Community Member
Updated by evsm1982
Suppose I have a model that contains 20000 nodes out of which 7000 random nodes reference a local csys. How can I assign these nodes to a different csys?
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    hi EVSM1982
    humh....
    I don't know whether hypermesh can select nodes by csys or not.
    you can try this way :
    1) edit a text file contains below template commands (copy these commands to your notepad and save it as any name, example file 'mark_node_local_csys_template.txt'):
    *nodes()
    *before()
    *string('hm_createmark nodes 2 {')
    *format()
    *if([inputsystemid > 0])
    *field(integer,id,0)
    *string(' ')
    *endif()
    *after()
    *string('}; hm_highlightmark nodes 2 h')
    *output()
    2) Enter panel page Post>>Summary
    - select file the template file that you saved above
    - enter a file name for output file, for example file name 'mark_nodes.tcl'
    this will be a tcl file contains tcl command to mark the node with csys id > 0 (local csys)
    - click 'summary'
    - close pop-up window
    3) Enter panel page Analysis>>System>>assign
    now you run tcl file 'mark_nodes.tcl' from menu File>>Run or standard toolbar
    the tcl file will mark nodes and highlight them
    anyway, it's complex. so, good luck
    regards,
    tinh
    User: "evsm1982"
    OP
    Updated by evsm1982
    Tinh, also work.
    Thank you very much!
    User: "tinh"
    Updated by tinh
    oh, I've just read Hw11 help and found a very simple command to do that. You enter panel system>>asign then open command window from menu View>>CommandWindow and type in this line:
    *createmark nodes 2 'greater than value' inputsystemid 0 ; hm_highlightmark nodes 2 h
    and then press enter. This command will select nodes with csys id > 0 (local systems)
    if you want to indicate an unique system id, just replace 'greater than value' by 'equal to value'
    I amaze that it works in Hw10 also, but in help of Hw10 it was not documented !
    Regards,
    tinh
    User: "evsm1982"
    OP
    Updated by evsm1982
    Hi Tinh,
    I've tried your second solution but, if I have let's say systemid 13,14,20 , and I want to select just nodes assigned to 13 system with the command || *createmark nodes 2 'greater than value' inputsystemid 13 ; hm_highlightmark nodes 2 h || , he will select all the nodes assigned to 13,14,20 systemid. I've found || *createmark nodes 2 'equal to value' inputsystemid 13 ; hm_highlightmark nodes 2 h || is the wanted command.
    Thank you for your time!
    User: "evsm1982"
    OP
    Updated by evsm1982
    Tinh,
    This is the easiest way. Thank you for your time.
