gerber mesh file export
Good evening. I installed Altair feko 2021.2 for antenna design. I wanted to export the CADFEKO Mesh file into Gerber format, but I can't. Here is the step followed: Home->Export->Mesh->Gerber mesh. A window opens with an empty file named Img. If someone can help me how to do it?
version-2021.2 is rather old but I just tried with the latest 2023.2 Legacy version and the export is working without any issues (Gerber export is not supported in the 2023.2 new CADFEKO but only in Legacy CADFEKO).
Thank you again. PLease, can you send the website where i can download the lastest 2023.2 legacy version?
It is the same installation file for both new and Legacy version, available on AltairMarketPlace:
https://altairone.com/Marketplace?tags=647191d4d886b019579f164a&tab=Info&app=Feko
After installing, you will see the option to enable and disable Legacy version under the "Utilities" tab of the Feko launcher.
