Trouble with License Activation for Student
Hi there, I believe I have a problem activating my student license, as when I try and import an stl file, I get this error code in Hyperworks "Warning: Unsupported cards found in the I/O options section have been written as unsupported control card.
Summary:Feinput finished with 0 errors and 1 warnings."
I know the issue is not with the stl file itself, as it has worked in Hyperworks for other individuals and I can open it in more basic 3D software programs.
When checking the license log in systems, I note these messages.
[11/21/22 22:14:23] System Error: No Auth Token in HHWU Config
[11/21/22 22:11:17] Activating features...
[11/21/22 22:11:17] Trying to activate...
[11/21/22 22:11:17] Deactivating features...
[11/21/22 22:11:17] Activating...
[11/21/22 22:11:17] Activating required features
[11/21/22 22:11:17] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneAP, HyperWorks, HWHyperMesh
Error Code: 9
Error Description:
Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
[LOCAL] C:\Program Files\Altair\2022-edu\security\altair_lic.dat - (Err: 9) Feature not found
License Path: C:/Program Files/Altair/2022-edu/hwdesktop/../security/altair_lic.dat;C:\Program Files\Altair\2022-edu\security\altair_lic.dat
[11/21/22 22:11:18] Checked out HyperworksEDU ( local )
[11/21/22 22:11:18] Activating optional features
[11/21/22 22:11:18] Activation Done
[11/21/22 22:14:15] Updating idle status...
[11/21/22 22:14:15] Updating Idle [OK]
I'm thinking it might be an error in the local ethernet ID. When I use the tool provided by Altair to find the address, it match the ip cofigaration of something called "Ethernet adapter Ethernet 5" and not the "Ethernet adapter local area connection". I've also, when using ipcof/all in command prompt got the connections listed of "Wireless LAN adapter Local Area Connection* 1", "Wireless LAN adapter Local Area Connection* 12", "Wireless LAN adapter WiFi", "Ethernet adapter Bluetooth Network Connection". Is this issue preventing me from using the software properly, or is it something else?
