Trouble with License Activation for Student
Amira
Amira Altair Community Member
edited November 2022 in Community Q&A
Hi there, I believe I have a problem activating my student license, as when I try and import an stl file, I get this error code in Hyperworks "Warning:  Unsupported cards found in the I/O options section have been written as unsupported control card.
Summary:Feinput finished with 0 errors and 1 warnings."
I know the issue is not with the stl file itself, as it has worked in Hyperworks for other individuals and I can open it in more basic 3D software programs.
When checking the license log in systems, I note these messages.
[11/21/22 22:14:23] System Error: No Auth Token in HHWU Config
[11/21/22 22:11:17] Activating features...
[11/21/22 22:11:17] Trying to activate...
[11/21/22 22:11:17] Deactivating features...
[11/21/22 22:11:17] Activating...
[11/21/22 22:11:17] Activating required features
[11/21/22 22:11:17] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneAP, HyperWorks, HWHyperMesh
Error Code: 9
Error Description:
Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
[LOCAL] C:\Program Files\Altair\2022-edu\security\altair_lic.dat - (Err: 9) Feature not found
License Path: C:/Program Files/Altair/2022-edu/hwdesktop/../security/altair_lic.dat;C:\Program Files\Altair\2022-edu\security\altair_lic.dat
[11/21/22 22:11:18] Checked out HyperworksEDU ( local )
[11/21/22 22:11:18] Activating optional features
[11/21/22 22:11:18] Activation Done
[11/21/22 22:14:15] Updating idle status...
[11/21/22 22:14:15] Updating Idle [OK]
I'm thinking it might be an error in the local ethernet ID. When I use the tool provided by Altair to find the address, it match the ip cofigaration of something called "Ethernet adapter Ethernet 5" and not the "Ethernet adapter local area connection". I've also, when using ipcof/all in command prompt got the connections listed of "Wireless LAN adapter Local Area Connection* 1", "Wireless LAN adapter Local Area Connection* 12", "Wireless LAN adapter WiFi", "Ethernet adapter Bluetooth Network Connection". Is this issue preventing me from using the software properly, or is it something else?
Welcome!
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
    The license looks to have been checked out correctly? If it were not, you wouldn't be able to open HW at all.
    Are you trying to use legacy HM or the new interface?
    I think stl import is only supported in the new interface for the student edition (import as solver deck)
  • Amira
    Sorry, I'm quite new to this all. How can I tell if it's the legacy or new interface?
  • Amira
    Ok so I believe that I am using the new interface. However despite importing my stl file as a solver deckimageimage
    The loading bar at the bottom quickly changes to "Translator doesn't exist" before resetting to normal?
Welcome!
Welcome!
