Time Step Less or Equal Zero Error
Hi Everyone,
I am working with Radioss. I use TYPE 7 and TYPE 2 contact for this model (You can see from an image below). I set the Engine file as shown in image below.
In the beginning, Radioss run normally. But later found a problem, Time Step Less or Equal Zero Error.
(Previous model, I set nodal time step in engine file less than zero but Radioss run normally.)
Can anyone take a look into my model what's wrong. what change, I have to make.
Thank you in advance.
1 - 6 of
61
Hi,
From the engine out file we can review what is causing very low time step.
It can be an element, a node or an interface.
•For an element, check the related material (especially its Young modulus and density in case of an elastic-plastic material; and its viscosity in case of a visco-elastic material). There must not be an error in the units system that this data is given in.
Check the size of the element, since elemental length is proportional to time step. If some elements are distorting badly during simulation it will lead to very low time step and the run will terminate. In this case use small strain formulation (in the property card).
•For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
•For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface. Check the interfaces defined in the model for any penetrations.
