🎉Community Raffle - Win $25
Join and Win
something wrong in far field pattern result when using near field source
Marcus ChangUser: "Marcus Chang"
Altair Community Member
Updated by Marcus Chang
Dear all,
I have an exercise which I would like to extract near field from a horn antenna and import to another simulation (all in FEKO platform), then there is a weird result shown in the video as below link I just uploaded:
https://drive.google.com/file/d/1-NGAV75rxH2zKfahMF4qN6I2l8BpKN8c/view?usp=sharing
 You can see the far field pattern with near field source I imported is completely opposite to original one. I would appreciate if anyone can show me how to simulate correctly.
BR/Marcus
1 - 25 of 251
    Hi @Marcus Chang,
    In the model where the near field is requested, the Start and End values of U are defined from positive to negative:
    Therefore when trying to use as near field source, you should rotate the workplane of the source (or of the field data) so that the orientation agrees with the original model.
    OP
    Hi @Torben Voigt,
    Thanks for you immediately support, and it works now.
    Here is another question for another exercise, I would like to use a horn antenna to radiate on a metallic sphere, then try to use the same horn antenna to receive power reflected from the metallic sphere.
    First, I extract near field data from a horn antenna I just run (please check file named horn_X band_190309.cfs).
    Then in simulation 1 (please check file named FF source_PEC.......cfs), I use this near field source as TX and radiate to a metallic sphere, then I can get the results of the near field from a surface of sphere, and extract its as the near field source for simulation 2 (please check file named temp_190313.cfs)
    In simulation 2, I use the near field source from previous results (on surface of sphere) and radiate to a near field receiving antenna (the same horn antenna) and try to get the result that how much power it can receive.
    However, I get two different results from different method, one is using far field receiving antenna, another one is near field receiving antenna as below.
    And also, it is weird that the power is negative, could you please help us check again what's happening to this simulation?
    And the last question is, how could we get results of the far field pattern from receiving antenna, not just power calculation?
    BR/Marcus
    onlyonechancy@gmail.com
    Hi @Marcus Chang,
    I would need the *.cfx files to investigate.
    OP
    Hi @Torben Voigt,
    I already update attached file as below, please check it.
    BR/Marcus
    Hi @Marcus Chang,
    Let check what you did:
    1. In horn_X band_190309.cfx you calculate and save the near field and the far field of the horn antenna.
    2. In FF source_PEC sphere_sphere surface NF source_190312.cfx you replace the horn by the near field data from 1. and to illuminate a PEC sphere. Here's mistake #1: The orientation of the near field is wrong (the horn is looking downwards):
      This would be correct:
      Mistake #2: The near field data is placed at z=0, while in model 1. it is placed at z=0.2138m.
      Around the PEC sphere you request a new near field to capture the radiated field from that sphere. Here's the mistake #3: The near field request has the same radius as the sphere, so the near field point are calculated exactly on the PEC surface. For acurate near field results a field point should not be closer than 1.5 x the edge length of the surface mesh.
    3. In temp_190313.cfx you compare the received power of an RX near field antenna and an RX far field antenna. The results are different because of mistake #2 and also because of warning WARNING 39270: A receiving antenna described by a far field pattern is positioned too close to a scatterer, far field condition not met. It says that that a source (the field of the PEC sphere) is too close to the RX far field receiving antenna. In general for far field sources (or receiving antennas) a far-field radius should be considered.
      I also decreased the increment beween the near field points of model 1. to ensure accuracy. The final results agree quite well:
      Note, with larger distance between source and RX antenna (or plane wave instead of the near field of the PEC sphere) the difference would be around 0.2 dB, because of omitting Warning 39270.
    The three new model files are attached:
    OP
    Hi @Torben Voigt,
    Thanks for you support.
    About Mistake #2, the location of receiving antenna (RX) should be the same as transmitting antenna (TX).
    So I place the near field data at z=0 rather than z=0.2138m. (horn aperture is placed at z=0).
    Then I increase the distance between horn and metallic sphere to 72 times lengths of wavelength. (2*D^2/lambda=72 lambda) to satisfy far filed requirement, so that warning 39270 is not shown again.
    Finally I can get the results shown as below, please check:
    But... this results do not accord with the number calculated by MATLAB, the coding is shown as below, please check:
    f=10*10^9;
    c0=3*10^8;
    lambda=c0/f; %units: m
    lambda
    Pt=1;
    Gt=18.3; % simulated in FEKO
    Gr=18.3; % simulated in FEKO
    r=3*lambda %units: m, radius for metallic sphere
    RCS=pi*r^2
    R=72*lambda %units: m, distance between sensor and object
    Pr=Pt*1*Gt*Gr*RCS*(lambda^2)/((4*pi*R^2)*(4*pi*R^2)*(4*pi))
     so that I can get Pr=177.56e-09 (W), 177nW approximately, almost twice the power of the results (100nW) simulated in FEKO.
    Second question is, is it possible to get far field pattern of the reflected field of sphere?
    BR/Marcus
    Hi @Marcus Chang,
    Unfortunately I'm not sure about the Matlab code. Maybe someone else (@mel, @JIF) could have a look?
    You can get the far field pattern of the reflected field of sphere by doing this:
    This will then only use the contribution of the surface currents of the sphere.
    OP
    Dear @Torben Voigt @mel @JIF
    MATLAB code is just a easy way to calculate it.
    But it is a simple and fundamental formula as below:
    while the RCS value I use is:
    here Gt=18.3=Gr, lambda=0.03(m), r=3*lambda, R=72*lambda (=2D^2/lambda, D=2*r) and Pt=1W (in Feko),
    then I can get the value of Pr is equal to 177nW, however, the results simulated in Feko is less than 100 nW.
    And thanks again for your suggestion of receiving far field pattern of reflected signal, I will try it and get back to you if there is any further questions.
    BR/Marcus
    OP
    Dear @Torben Voigt,
    For the suggestion of the contribution of the surface currents of the sphere you provided, it seemed not work as below,
    there is no differences when I use it, please check:
    BR/Marcus
    Hi @Marcus Chang,
    If you get identical far field results for both, then I assume you have in addition 'Calculate only the scattered part of the field' activated:
    This will in this model of course give the same results, as the sphere is the only scattering object. So, in both cases you will get the scattered field from the sphere surface.
    OP
    Dear @Torben Voigt  @mel @JIF,
    Recently, I try to run some simulations for metallic sphere and corner reflector respectively, the results for these simulation is weird, the received power bounced by metallic sphere is larger than corner reflector.
    But actually, the RCS for metallic sphere should almost 10 times smaller than corner reflector, no matter it's calculated by formula or simulated in FEKO (I also upload these simulations as attached, please check)
    So I would like to check with you again, to see what's happened to the setting in FEKO.
    BR/Marcus
    Hi @Marcus Chang,
    For the corner reflector you're using PO, but with PO no multi-reflections between PO faces are taken into account. A corner reflector is THE classical example where PO is not feasible. Furthermore, the asymptotic methods (PO, LE-PO, RL-GO and UTD) are only feasible if the model is electrically very large, e.g. 20 lambda, bigger is better, but the corner reflector is only around 4 lambda. You should definitele use MoM / MLFMM here. Same goes for the sphere, which is only 3 lambda in radius.
    When calculating the scattered field of the reflector and the sphere correctly (MoM), the received power of the reflector is around 10 times higher than that of the sphere.
    OP
    Hi @Torben Voigt,
    It works now, the received power for RX antenna in situation of corner reflector is also 10 times larger  than metallic sphere.
    Thanks for your suggestion!
    BR/Marcus
    OP
    Hi @Torben Voigt,
    If I would like to do multi-frequencies simulation, such as with a bandwidth, how to use script to import near field data for every single frequency in this case.
    Because when I try to run a multi-frequencies problem, I use the first .cfx file and add multi-frequencies setup, I can get a NF data with multi-frequencies.
    But when I use this NF data as my equivalent source (NF source), the error message was shown as below:
    ERROR 3392: The near field source cannot be used inside an implicit frequency loop (frequency dependent data)
    And I check there was a member had similar problem, it seemed like I need to solve it with EDITFEKO.
    Can you provide us an example (EDITFEKO), for this three files, such as how to write a loop then I can finally get a plot with RCS values in a bandwidth, such as 9-11 GHz.
    BR/Marcus
    Hi @Marcus Chang,
    It's not necessary to use EDITFEKO for this anymore. In principle you need one configuration per frequency. Also you need one Field data per configuration. Please have a look at the attached CADFEKO script.
    • It imports field data and makes sure that the 'start reading from line' is correct
    • It creates near field sources
    • it sets the right frequency
    It was all created using Macro recording and a little editing. You can use it and fit it to your model.
    Open base_model.cfx and run the script from there, it should give you some insight in the process.
    OP
    Hi @Torben Voigt,
    Due the the version problem, could you please help us provide the modified file in previous version (2018.2-338937 (x64)) in this transition period?
    BR/Marcus
    Hi @Marcus Chang,
    Here you go:
    Please install FEKO 2019 soon. It's hard to provide support for different versions.
    OP
    Hi @Torben Voigt,
    Here is another question for scripting related to this case.
    If I have three E-field and H-field data, and I would like to use it as my source in next simulation.
    So I write a script as attached, however, it seemed like I must to input file named including .efe or .hfe these characters.
    I want to let the input looked like this:
    but I don't know how to modify this script, such as how to add additional .efe or .hfe these characters to the code as below:
    properties.EFieldFilename = [[02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_]]..i
    properties.HFieldFilename = [[02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_]]..i
    If I use the script as shown as above, it will be looked like:
    BR/Marcus
    Hi @Marcus Chang,
    the code temp.lua seems to work. It successfully adds 3 NearFieldData in CADFEKO:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.cf66ed0fb86a48afa0ac85c9ad8b63d7.png
    What's still missing is the 'Start reading from line' which is 1 in all cases. You should change line 15
       properties.ReadFromLine = '1'    to    properties.ReadFromLine = '1+(20*20)*'..(i-1)
    20 is the number of field points in x and y, so this will ensure that the starting number will be like 1, 401, 801.
    Hope this helps!
    OP
    Hi @Torben Voigt,
    I've tried to use this .lua file to run the simulation, however, it still doesn't work, and the error message is shown as below, please check:
    ERROR 30968 in line 40 of the file test2.pre: Error in opening the file 02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_1
    To my understanding, the input characters should be like this:
    02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_1.efe
    not like this:
    So I would like to check with you, how can I write a propreiate code to generate the character string shown as above, such as:
    02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_2.efe
    02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_3.efe
    BR/Marcus
    Hi @Marcus Chang,
    I don't think that the extension (efe / hfe) are needed. However, you can do it like this:
    properties.EFieldFilename = '02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_'..i..'.efe'
    properties.HFieldFilename = '02_NF source_PEC corner reflector_190406_sphere placed 72 lambda_alt_NearField_'..i..'.hfe'
    OP
    Hi @Torben Voigt,
    Now I have a question that, is it possible to change the size of corner reflector (s=3*c0/(fmin+f_inc*i), i=0 to 2) for each simualtion (per frequency, such as 9GHz, 10GHz and 11GHz in this case), if it can, can you help me modify this .lua file?
    BR/Marcus
    Hi @Marcus Chang,
    No, in FEKO you will always have one mesh (= one geometry) per model. You can of course use the Parameter Sweep to automatically create different models.
    OP
    Hi @Torben Voigt,
    Recently, I tried to simulate a near field source radiate a signal to CATR reflector and use near field receiving antenna to receive the power of scattered field.
    The schematic diagram is shown as attached, please check it.
    And I found that the size of the reflector is 0.37m*0.37m, around 12 times lambda (operating frequency = 10 GHz)...if I would like to use GO method for it, it is smaller than 20 times lambda you suggest.
    Due to I spent almost 2 days to solve this kind of problem by using MoM/MLFMM method, is it possible to use GO method in this case?
    What is the tolerance range for this problem if I use GO method not MoM method?
    Or is there any other suggestion, such as modify the setting, to boost the simulation?
    BR/Marcus
    Hi @Marcus Chang,
    20 lambda is just a rough estimation for RL-GO, it always depends on the model.
    Your model seems ideal for PO or LE-PO (only one interaction on the reflector). The solution should be quite accurate. RL-GO would work but it will require much more time because the near field source will be transformed into a spherical modes source first (and same for the Rx antenna).
    Just apply PO (full ray tracing) to the reflector face and you should be good. Also compare with LE-PO (full ray tracing).
