Altair RISE
Nominate Yourself Now!
Error running Hypermesh 2017 with command prompt
User: "tbaldan"
Altair Community Member
Updated by tbaldan
Hi,
I have a tcl script to model simple bracket and export Abaqus solverdeck file. My script works fine in Hypermesh command prompt. However, I want to run that script without GUI from command prompt. When I try, I got Error:  'The file being opened for reading does not exist.'
My command :   C:\Program Files\Altair\2017\hm\bin\win64>hmbatch -tcl E:\Automatic_Mesh_Generation_Scripts\Mid_to_Export.tcl
My tcl script:
*geomimport 'auto_detect' 'E:/TARIK/Scripts/Hypermesh_Scripting/DENEME_CAD/from_sorhan/ASY-0005865-6C46-6622-BA1_proposal_2.stp' 'CleanupTol=-0.01' 'DoNotMergeEdges=on' 'ImportBlanked=off' 'ScaleFactor=1'
*end_batch_import
*createmark comps 1 'all'
set number_of_component [hm_getmark comps 1]
*createmark surfaces 1 'all'
*midsurface_extract_10 surfaces 1 -1 0 1 1 9 0 20 0 0 10 0 10 -2 undefined 0 0 -3
*deletemark comps 1
*createmark surfaces 1 'displayed'
*createstringarray 1 'breakconnectivity 0'
*hm_batchmesh2 surfaces 1 1 1 'E:/Automatic_Mesh_Generation_Scripts/batchmesh/durability_3mm.criteria' 'E:/Automatic_Mesh_Generation_Scripts/batchmesh/durability_3mm.param'
proc CreateSpiders {args} {
        if {[array exists ::hole_nodes] == 1} {
            array unset ::hole_nodes
    *createmark components 1 'all'
    set holes_comp [hm_ce_gethmholes 1 20 0 1 0 1]
    foreach e $holes_comp {
        #puts $e
        set s_l [lrange $e 1 end]
        set comp_no [lindex $e 0]
        foreach h $s_l {
            #puts $h
            set short_list [lindex [lindex $h 1] 0]
            #puts $short_list
            lappend ::hole_nodes($comp_no) [lindex [lindex $short_list 0] 0]
    #eval *createmark nodes 1 $hole_nodes
    *collectorcreateonly comps 'spiders'
    foreach cmpt [array names ::hole_nodes] {
        #puts $cmpt
        eval *createmark comps 2 $cmpt
        eval *createmark nodes 1 $::hole_nodes($cmpt)
        *createstringarray 5 'link_elems_geom=elems' 'link_rule=now' 'relink_rule=none' 'tol_flag=1' 'tol=1.000000'
        *CE_ConnectorCreateByMark nodes 1 'bolt' 1 components 2 1 5
        *clearmark comps 2
    #realizing the connectors
    *createmark connectors 1 'by component' 'spiders'
    *createstringarray 4 'ce_notuseijk=1' 'ce_boltmindiameter=0.000000' 'ce_boltmaxdiameter=100.000000' 'ce_systems=0'
    *CE_FE_RealizeWithDetails 1 'bolt' 'abaqus' 1001 7 0 20 1 4
    *CE_FE_GlobalFlags 0 0
    *deletemark connectors 1
CreateSpiders
*feoutputwithdata 'C:/Program Files/Altair/2017/templates/feoutput/abaqus/standard.3d' 'E:/TARIK/Scripts/Hypermesh_Scripting/Input/Brakcket.inp' 0 0 1 1 2
1 - 7 of 71
    User: "tinh"
    Updated by tinh
    Should be quoted
    'C:\Program Files\Altair\2017\hm\bin\win64>hmbatch' -tcl E:\Automatic_Mesh_Generation_Scripts\Mid_to_Export.tcl
    User: "tbaldan"
    OP
    Updated by tbaldan
    Hello Tinh !
    Thanks for reply, I tried quoted  command as:
    'hmbatch' -tcl E:\Automatic_Mesh_Generation_Scripts\Mid_to_Export.tcl
    but I encountered errors shared below. Are there an error in my script shared with older post?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f12974757967c3b5a7ce54f0752d70a3.png
    User: "tbaldan"
    OP
    Updated by tbaldan
    Hi,
    I could not find solution. Do you have any other idea?
    User: "tinh"
    Updated by tinh
    Try lòading abaqus profile at fist.
    User: "tbaldan"
    OP
    Updated by tbaldan
    How to do it?
    Are there any command for command prompt or .tcl code?
    Thanks
    User: "FabioC"
    Accepted Answer
    Updated by FabioC
    Hello,
    As @tinh suggested, you need some lines at the top of your tcl file, to call HM first.
    Below I pasted the block I used in my tcl file, it worked for me but might be different in your case.
    Anyway you can find this lines in the command.tcl file created automatically when you launch Hypermesh.
    *begin 'version 2017'
    *menufilterset '*'
    *menufilterdisable
    *settopologydisplaymode 0
    *ME_CoreBehaviorAdjust 'allowable_actions_policy=TC_lite'
    *elementchecksettings 6 0 0 1 1 6 0 6 0 6 6 6 0 0 0 0 0 0 0 0 0 0 0
    *templatefileset 'C:/Program Files/Altair/2017/templates/feoutput/optistruct/optistruct'
    *enablemacromenu 1
    #Import geometry.
    User: "tbaldan"
    OP
    Updated by tbaldan
    Thank you FabioC and tinh! Even if there are some error on command prompt window, input file is exported properly.
    I changed the begining of the code as you said FabioC. I share same code for Abaqus User Profile below.
    *menufilterset '*'
    *menufilterdisable
    *templatefileset 'C:/Program Files/Altair/2017/templates/feoutput/abaqus/standard.3d'
    *enablemacromenu 1
