PSHELL Thickness
Dear all,
For instance, I have a surface model of a Tube with D = 400mm and thickness = 16mm. So, the middle surface (MS) in the model lies at a diameter of 384mm.
So, I've 2D mesh the middle surface and know I have created a PSHELL property to define the thickness corresponding to the tube.
What thickness should I consider to represent my tube, 8 or 16mm?
Thank you in advance.
1 - 4 of
41
If the wall of your tube has a thickness of 16mm you should assign 16mm in your PSHELL card in the 'T'-field.
You can check your MidSurface modeling with the '2D Detailed Element Representation'
