Hi,
I am working on OS-1360: NLSTAT Analysis of Gasket Materials in Contact tutorial. But it is showing Gasket error after running. Find the attached image
Hi @Arul
Can you share a screenshot of MGASK material card?
Hi ,
Pls find the image
Hi Arul,
Leave YPRS blank and try again.
Hi Prakash,
I tried but same Error..
Regards,
Arul
Try this model
I attached the fem file. Pls Check.
Try this file. Curve is not defined in increasing order in one of the tables.
working fine. Thanks for your help.
Can you please send the solved file.
Hi @Arul
