After I run circuit macro, I face this issue that is "Java running errors" on both Flux2019, 2020.
Could you suggest how to overcome this?
Thanks.
Hi,
Can you share your Flux project (zip format).
Best regards.
Hi, Can you share your Flux project (zip format). Best regards.
Hi Abdesssamed,
I already found the solution for this issue. I paste the Python script (record) on command and hit on RUN
Good to hear this. thanks for your feedback.
Hi,
Best regards.
