Hi,
Using script, I want to select the elements in a component collector between two nodes taken in one direction. The other direction distance can be taken randomly (high value). can anyone suggest a solution for this?
In HyperWorks 2022.2 i want to do this
Thanks in advance
Your best bet is probably "by cylinder" with hm_createmark.
https://2023.help.altair.com/2023/hwdesktop/hwd/topics/reference/hm/hm_createmark.htm
Or let the user pick them with *createmarkpanel. Then the user can select by path (at least in the new interface).
