Refine Tetramesh
1 - 5 of
51
Hi Rahul,
I try be clearer:
I have a surface mesh of a vertebra. Now I want to fill it with tetra solid elements. So far it is easy. However, I want to fill it in a way that I have small tetras at the surface (corresponding to my surface mesh) and larger elements in the center (see ). Is this possible?
Thanks, J
you can keep smaller element size for enclosed volume 2d mesh & bigger element size for tetrahedral mesh.Make sure to have enclosed volume for 3d mesh.
